help me fix this??
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by ricky e, Jan 31, 2009.
  1. ricky e
    ricky e Virgin Detailer
    when i bought the car these wern't that obvious but now they are everywhere.
    any idea's on fixing these?
    ive tried polishing . . alot of polishing >.<
    also used a tube of scratch x but nothing
    any help would help.
    its like stone chips but in a swirl?? i was thinking of using 2000 grit wet/dry and polishing butit might make things worse.
  2. Nica
    I've seen this before and regrettably it's not good news. What left that behind is some sort of machine (rotary or DA) and the individual that used the machine used a pad (foam or wool) that had some sort of contaminant (could be dirt, small pebble, I've even seen metal shavings) and polished the area and what your picture shows are the results of such a polishing job.
    The vehicle I saw this done too was at a body shop, the person polishing the vehicle dropped the wool pad on the floor picked it up put it on the rotary (Dewalt) and went to "work" on the vehicle at the end the vehicle looked exactly like your picture.
    Regrettably, the scratches are quite deep, through the clear coat so even if you wet sand you wont be able to remove all the deep scratches completely...but it will make them less noticeable.
  3. ricky e
    aww :/ whats the best method to get rid of them then?
    and thanks for the reply
  4. Nica
    Well because they are so deep the only way to completely remove all those circle like scratches is to repaint the area.
    Like I said you can try to wet sand the are...but you should be careful as to not to remove too much clear, who knows how much clear you have to play with either so if you don't have a paint gauge just be careful. Now wet sanding the area wont completely remove them but it will reduce them a bit.
  5. ricky e
    Thanks again will try my best
  6. Nica
    Let us know how things work out for you, feel free to ask questions, we enjoy questions around here :thumb:
  7. MrPolished&Waxed
    MrPolished&Waxed Obsessive Detailer
    what panel is that on? and how about another pic?
  8. ghost28
    ghost28 Birth of a Detailer
    that mark is from an EGG that was thrown at the car.....i have seen this many times before.....when an egg hits the paint the egg crushes and the sharp pieces of shell put that small circular set of chips in the car.....like snowflakes....no two are alike.....unfortunetly most of the time they are quite deep....
    try a sand and polish but dont sand too deep....
  9. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    I would agree with this or even bird crap will do that.
  10. P1et
    It looks like an egg was thrown at the car. One of the most frustrating things to happen to your paint as there isn't much you can do about it.
  11. JohnyB
    JohnyB Birth of a Detailer
  12. Nica
    Really egg...mmm...can't say I've ever seen that...good to know though.
  13. advs1
    advs1 DB Forum Supporter
    jep its da egg. happened to my truck. a little 2500 sand paper and a light polishing took care of it
  14. Nica
    Cool beans, I look forward to see how this turns out then :thumb:
    Always learn something new every day :peace:
  15. TheJag
    TheJag Birth of a Detailer
    i concur (hehe i feel like a doctor now) My friends RX-8 had the same marks on it. sadly it was all the wat down to the primer so all we could do was get soem touch up paint and clearcoat. it turned out OK but you could still see it at the right angle. it sucks that there are a-holes out there that would do this to a car. hope everything turns out okay! hopefully you'll have a better time getting atouch up paint than i have! white diamond pearl for my supra has been discontinued by toyota... curses.
  16. ricky e
    will get progress pics up shortly , kinda glad i know how it's been done but i now know how to deal with the problem so thanks alot!
    ill try some wet/dry and touch up paint with a lil bit of clear coat and follow up with some good polishing =]
  17. sal329
    sal329 Nuba Guru
    Good luck with it let us know how it turns out
